350 wheel hp
chickenknob
Car: 1993 Nissan 180SX SR20DET
2002 Honda S2000
hello i'm new to the place and just wanted to ask somethings
i have a ka-t that is very stock and i have about 250hp stock injectorsstock mafturbo good for 450hpintercooler good for 400hp
i'm looking for 350hp on stock engine.
so far i'm waiting on:nismo yellow 555cc injectorsz32 mafJWT tuned ecugreddy Boost Controller
looking for:fuel pressure regulator??(which one do i need)and what else do i need???
any help would be great thanks!!
Modified by chickenknob at 9:12 AM 2/4/2006
wild_maxx
Car: 90 TT pearl yellow z32
WELCOME to nico.... you setup looks great and you have just about everything covered for your HP goals. What turbo is that? kinda looks like a t3 super 60 to me....IDK. you don't need an aftermarket FPR the stock one is fine. Do you have any gauges to monitor whats going on with your engine?
you may wan't to get some colder sparkplugs... one step colder should be good and gap them to .030 or so you will def. need a better fuel pump if you don't already have one. i reccomend the walbro 255lph. alot of people run them with no problems.
you can get 350HP out of the stock motor but TUNING is the MOST important part of this. Do you have a wideband O2 for tuning? If not you should take it to a dyno tuner asap.
Good Luck and great job so far.
Florida240sx
You got anything to fine tune with or wideband?
Jookmasta
post ur complete setup so we can give ya some good advice without speculating what ya have. also welcome to nico and ur setup looks nice.
namwons_240
Car: 97' 200sx ser
u forgot one major part in the fuel chain...FUEL PUMPS...get a walbro or z32tt pump then with all that u said and good tune your all set man
4felix20
Car: Emerald Blue S14
and if you do want an fpr, you can use a universal one. an adjustable FPR would be good for little pressure tweaks..aeromotive makes solid stuff.
nissanfanatic
Car: 1992 Nissan 240sx SE
You don't have anywhere near 250whp...
What you listed will get you to 350whp. The JWT ECU will take care of timing/fuel curves. Slight fuel tuning could make some more power along with maybe a couple degrees of base timing advance.
There is a link to my setup in my signature.
chickenknob
2002 Honda S2000
i have a tt supra fuel pump and oil pressure, boost and egt greddy gauges
i'm thinking of going with an aem wideband.
thanks for the post
chickenknob
2002 Honda S2000
Does anyone know where I can buy a pipe or pipes that connects to the throttle body and runs by the battery down to the side of the intercooler???
Florida240sx
Goign to your local exhaust shop.And they can make it for real quick.Might be mor eexpensive than online.But it will fit perfect.And no shipping charge.So it work out to be abotu the same price if not cheaper.
uvamosk
I feel like i wasted my money buying Wiesco pistons, and crower rods... becuase people hit 350hp on stock block... I should have just bought 3 Ka's with the money and tuned the 1st one to 400hp and when it blows throw in another.. one ... LOL
hannibal
Car: Red Line to Glenmont
nissanfanatic wrote:You don't have anywhere near 250whp...
Curious... why do you say that??
4felix20
doesn't the stock MAF max out around 220hp or something..? and the stock injectors can't support 250hp either, i don't think.
jmwenick
Car: 1991 240sx Base Model
I thought someone hit 286 on the stock MAF, but i'm not sure how much hp our injectors can handle
nissanfanatic
The fuel pressure required to allow stock injectors to support that would most likely kill them brevi tempore.
In the shortest possible explanation, nobody makes 250whp on a FMU and stock injectors setup.
