huguetpj wrote:By the way, Ivan, what did you end up doing regarding the timing curve?
We started out with timing at about 20 degrees full vacuum. At zero vac about 28 degrees. At one bar about 20 degrees. Everything in between was interpolated.
This was a bit agressive for 93 octane and the efficency of this setup. Timing was backed down a couple degrees under boost.
Then a nice timing curve for RPM was brought in and everything is looking good. To really dial in the timing, I would need to spend another day on the dyno with an EGT gauge and watching KS voltage. This will happen when everything is back on the car after building jigs.
