evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Jan 23, 2007 9:15 am
if you have a base modle then it came without a LSD, someone could have added one before you I guess, just jack up the back of the car and put it in neutral with the e-brake off, now turn one wheel, if the other wheel turns backewards it's open and if they both go the same direction it might be LSD, next put the car in gear and try turning the wheel, if you can turn ne wheel with the car in gear then you got an open diff for sure
I'd assume the base model got the 4 spider R200 open diff which is better than the older 2 spider version, even in an open diff the tires try to turn at the same rate, the lsd simply adds resistance to help "lock" the 2 wheels at the same speed, when you have equal amounts of weight and traction on each side you get the same performance out of an open as a LSD it's in the turns that the LSD helps keep the inside tire loaded to prevent wheel spin
