350 Chevy Engine into 240sx
slim240sx
Im just looking up info on this, I figured I would start here
I know its possible, been done previouslyI was wondering on if anyone knew what it would take to put a 350 chevy engine into a 240sx, maybe just some ruff estimates on how much money it would cost
or if anyone knows a website or soemthing like that
Anand
Car: 95 Nissan 240SX
talk to Aries about it...
red240ne
Car: mmm...donuts
ok if you're looking for just a basic stock setup then probably...engine/auto transmission which you could normally get for around 500-2000 bucks depending on where you live. B&M shift kit--100 bucks
driveshaft could be another 100-200 bucks.
motor mounts could be around 250 bucks depending. I bet you could fabricate some from like grannysspeedshop.com that are made for an RX-7.
you'll need some welding skills and a TIG, because there's some custom work involved.
wiring harness kit/ECU and a lot of wiring skill, because it'll be a headache, but probably 250-500 bucks.
exhaust components--250-1000 depending on your setup.
You won't get much traction with the stock R200, so you'll need new rearend most likely. 250-1500 bucks
Beefier power steering pump--200 bucks(you could just put a bunch of fluid in the rack and lines, and plug all the wholes. you don't really need PS, but you DO need fluid.)
If you have skills and know a lot of people, then I would say you could do this for around 1500-2000. But it could be upwards of 10,000 if you start to get carried away, or even more. Go out and get to know some of the local V8 RX-7 guys, because they know more about this subject and are in basically the same situation.
Jookmasta
:Werd
deez1001
Car: Want a 97-98 240sx
Black 240 your car is tight and iI want mine to resemble it but with different rims and in blue... hopefully chrome rims
red240ne
Car: mmm...donuts
deez1001 wrote:Black 240 your car is tight and iI want mine to resemble it but with different rims and in blue... hopefully chrome rims
you brought this thread back for that?
and I replied to you for what reason?
encasemyheart
red240ne wrote:you brought this thread back for that?
Calm down there, tiger...
