alexf20c »
https://forums.nicoclub.com/alexf20c-u34818.html
Thu Feb 25, 2010 2:12 pm
with the proper backspacing, you will not rub the struts. the issue then is rubbing in a turn because as you push the wheel/tire further outward, you increase the chance of the tire rubbing the fender or frame.
are you set on 33x12.50s? if you're buying them new, i would recommend a 33x10.50 on a 7-8in rim. arguably better traction off road, better mpg, better highway performance, and the tires are typically cheaper.
if you get the tires in a metric size, they're even cheaper.
