So after searching for quite awhile for rims, I have found some that I like and may fit. I have been looking at VMR's, Avant Garde, etc looking for the "euro" look seven split spoke look with a bit of concavity in an 18" wheel. Well I think I found some finally and am wondering if a +33 offset will work? The reason I am going with 18's is that I recently spent 700$ on new tires and don't want to upgrade on tires as well. sooo any thoughts as far as fitment goes? I am completely stock right now. I MAY do the eibach kit eventually, haven't decided for sure. My tires are 245/45/18. Thanks in advance!!!
What is the width of the wheels? If it's 8-9 in, the wheel will sit very close to the fender, and may poke out just a little. You will not rub even if you put the Eibach springs on.
