DanielC »
https://forums.nicoclub.com/danielc-u110482.html
Wed Dec 31, 1969 5:00 pm
How many terminals are on the switch? I am not familar with 320 ignition switch details, but this is how a 521 ignition switch is set up. There are five terminals. They are Power in, Accessory out, Ignition out, Start out, and Ignition start out. Turn the key left, one click, and that hooks up power in, and accessory out only. Turn the key one click right, and that hooks up ignition out, and accessory out to power in. Turn the key two clicks right, against the spring, and that hooks up power in to start out, and ignition start out.
Ignition start out is used where there is a ballast resistor. It is wired so that power from the ignition switch goes through the ballast resistor, in the run position, and power bypasses the ballast resistor in the start position.
