320 door wing window rubber
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
Ted Heaton
Car: 64 Datsun 1500 Roadster
63 NL320 Sport truck
Well, a rainy Monday, 11-2-15, and a retired guy needs some task to do inside.
I dismantled one of my large collection of 320 doors (about 12!).
Noticed that amazingly the wing window rubber looked pretty good.
Never had removed one before so had at it.
A nuisance as the wing window pivot rivet has to be drilled out to release the window/frame
but I wanted to get the rubber out in one piece.
Now I know why there are no reproductions of this rubber.
It is very intricately designed with 2 different types of edges to hold it in the frame.
Very thick with many angles and special forming around the latch.
It is very hard to remove intact. It must be a bear to get it in.
But it is so thick you can manipulate it, even when the rubber is 50 years old.
I know reproductions of this piece have been attempted but have not been successful.
With the intricate shapes of this rubber, reproduction would be expensive and with
the parsimonious ( does that sound better than "cheap"?) reputation of 320
owners there is probably not a market for many.
But if any one wants to try to have reproductions made, this example may be good enough to copy,
and you can borrow this one for the attempt. It is for the right side door. I may have a good left side.
Here are some pictures of the rubber.
Ted.
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '62 PL 320 - parts :(
1 x '60 PLG-222
and many more Datsuns from 48hp to over 500hp
Thanks for the info Ted! I do have a spare door that I can dismantle for the quarter window seal, but not to thrilled about drilling out that rivet. I kind of figured you had too.
The really frustrating part of the reproduction for me here in the KCKS/KSMO area is that none of the vendors I go too will guarantee the final product. :confused: They will take my money, send it off, try to get the initial number below 100, but if they are not a close or exact fit - NO REFUND. Just cannot justify spending this kind of cash for a product they will not guarantee from their vendors. I do have a choice of US for low production numbers high price or China for high numbers high price - just no money back or another attempt to get right.
I going to head over to Independence/Raytown/East Kansas City to De Tray to see if they can chrome the inside of the brake and clutch master cylinder sometime next week and I'm hoping to find and contact a few local business that work/supply parts for the Ford and GM plants to see if they can help with the quarter window seal, rubber hose from the heater box to the fresh air plenum, and a D406 Hitachi Distributor (totally out of production and NO :mad: Standard Ignition is/will not make it ever again).
Andy
Return to “Datsun 320”
