ANVIL »
https://forums.nicoclub.com/anvil-u62019.html
Fri Jun 22, 2007 8:44 am
I have a s1 rb25det without any major upgrades, just the basic stuff to get the swap going and my goal is to make in the 320-350hp to the wheels. i had the car dyno'd last week and made 219hp which I think is right around where I should be right? that was on 90 octane pump and found out a few days later my boost solenoid wasnt functional. it might have gone out after the dyno but im pretty sure the dyno was only at about 5 psi. im going to be using torco from now on since 90 octane is the highest we can get out of the pump here in alaska unless i go for 104 for $9.50 a gallon or the 116 which I dont even know how much that is. I also will be purchasing an electronic boost controller planning to have it set at 10 or 11psi. what other mods can I do to get to my hp goal? im not sure which route I want to go yet and was hoping for some suggestions. id like to go the cheapest route if I can, i am on a limited budget. what I do have right now are:
Stock ECUFMICGreddy RS BOVWalbro 255 fuel pumpNismo FPRNismo TStatN1 Water Pump3" Downpipe w/ 3" piping straight to N1 Style mufflerHKS S30 Spark Plugs
nothing else comes to mind worth mentioning
I want to do a turbo upgrade but Im really unsure about it. those of you with turbo upgrades, what exhaust manifold did you go with? are there turbo upgrades available that would bolt in without a new manifold? would I be able to get to those hp goals with a turbo upgrade and a Power FC on stock injectors?
