312,000m where do i start on suspension?
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
ive put in tein stech springs so far.i definetly need new shocks,saving up for tein coilovers.does anyody make a complete bushing kit,or do i need to piece them.only want to do this one time.im going to use tein for all the parts i can and fill in with nismo on the rest.
chmercer
energy suspension sells various types of performance esque bushings.
nismofly
Car: 89 Nissan 240SX Hatch
i plan on using spl/nismo for all i can, then filling in the ones that they dont have with energy...
ive heard some not so good things about using the urethane, energy and whatnot, that it can cause binding, so im using it as little as possible
chmercer
well obviously if you use heim joints for everything there will be more performance benefits, but its more expensive. i believe if you buy everything spl sells you will end up with only normal bushings on your swaybars. dont quote me with that though.
Exar-Kun
Car: 2005 350Z
you can get heim joint sway bar endlinks :p
