C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu May 01, 2003 12:51 pm
Depends on the wheel. Offset refers to the position of the hub mounting surface in relation to the centerline of the wheel. This means the wheel width needs to be known to even know how the wheel will sit inside the wheelwell. Secondly, different types of spokes allow different amounts of caliper clearance. Some spokes arre thinker or thinner, and some are flush with the face of the wheel while others may be dished. There is no one size-fit's-all equation for this. A good way to reference would be to see if they have an application for the Z32 in the wheel you want. Make sure the wheel width is the same size you want. Some dished/multi-piece wheels will note a high caliper application, which means it is intended to clear calipers that protrude more than a typical sliding caliper that has inboard piston(s).
