Clawhammer »
https://forums.nicoclub.com/clawhammer-u53050.html
Mon Jul 23, 2007 9:05 pm
How much clearance do you have now? Measure it and see. IIRC, the 26mm calipers had to be used with a certain revision of the 7 spoke alloys that had a groove on the back of the spokes that allowed for the clearance. So the answer is maybe. It honestly wouldn't take you much to find out. Jack up your car, take a wheel off, take off the 2 19mm bolts holding the caliper on, bolt in the new caliper (doesn't have to be tight, just enough to hold it in place) and put your wheel back on and see how well it clears and guestimate the spacer size you need from there.
You might also want to consider ventilation. I don't think the SE's would give proper ventilation to the brakes.
