I'm sure I'll get flamed but INMHO you only need to change your oil.Transmission and differential fluid do not go bad at 30k miles. When your vehicle is old enough to replace belts & hoses that is the time to replace engine coolent.uncbeers wrote:I have to admit...I did not even think about the fact that the trans, etc... are covered longer. Thanks for knocking some common sense into me with that.
However, I do have an auto being a G35X. So I assume that still leaves some fluids to change around 30K?
I think on average you will find that a 401K is a money pit. That said it is a way to save money that most just can't do by themselves. Mine is down close $100k over the last year, or rather would be if I didn't remove it upon retirement and placed into a 72T account which has lost money every month since last August with the exception of one. Think of it like a legal pyramid game, in order for someone to win, someone has to loose.uncbeers wrote:The oil, air filter and cabin filter are already taken care of regularly. I was more concerned about the big items as I hit 30K.
And Telco, do you realize my 401K is sending me I OWE YOU notices right now (if I'm lucky)?! Thank god (or maybe not) retirement is a long ways off...
Thanks for the input all!
As far as Nissan prices compared to Infiniti's I had an estimate for and oil change using the new Nissan Ester oil. At Infiniti the quote was $199. At Nissan the quote was $99. Guess where I am going for that one.uncbeers wrote:
Does my logic seem sound? Also, can someone just confirm what all I should ask them to change on the X at ~30k? I am actually going to go to a Nissan dealer because I hate the closest Infiniti dealer (oh, how I wish Steve or Poyzin were closer!) and I hear Nissan's labor prices are always a bit cheaper.
Now flame away for the re-post...
When I purchase the car I was told the first two oil changes were free. Turned out the first was but they wanted to charge for the second and then honor a coupon on the book for one down the road somewhere. I told them no I was told the first two.Poyzinous wrote:Perry I'm worried if your dealer wants to charge $200 for an ester oil change. They must be adding other things to it without telling you. At my dealer its $110. Plus ester oil can be up to a 5000 mile interval, not just 3750 miles.
I have heard that on here as well. I don't want to take anything away from our Infiniti techs on here but it does seem we pay for having it done at Infiniti vs Nissan. I guess it goes right along with that whole American need for visual evidence in our luxury purchases. If we didn't all care at least a little about the badge wouldn't we be fine labeling our cars as Fords?!pfarmer wrote:
To me it seems surprising that there is that large of a swing in cost of doing something relatively simple such as an oil change between Nissan and Infiniti.
I have also heard that this applies to many other services as well, and not just locally.
Perry
As far as having all your fluids changed now or waiting consider the fluids we are speaking of. For example for oil it depends on how clean the oil is now (particle wise) and what the chemistry of the oil is (ph).uncbeers wrote:
I concur....Have a friend start it up and drive it around the block or something so that it doesn't spend more than a week without moving. A car is made to be driven. now everyone take my poll!!! pleasepfarmer wrote:
Personally I would see if there was just someone who could start it up once a week or so and drive it to church and back. This would help keep all of the seals functioning, dry out the moisture, cycle the battery, etc.
How so? If it extends the number of miles between oil changes it sounds like for that reason alone it would be close to break even assuming the cost of oil changes quoted from Nissan. If it is truly better oil then it seems like that may well apply to other vehicles as well, just maybe not as much of a necessity.infinitidude wrote:unless you have a vvel engine,the ester oil will be a waste of money,
