mpattdu »
https://forums.nicoclub.com/mpattdu-u122873.html
Thu Mar 24, 2011 12:52 pm
Greetings Rogue Drivers!
Last time I had my Rogue in for an oil change the service manager stapled a printout to my invoice that details the "Rogue 30K Miles Scheduled Maintenance" and price for each service. I've already concluded by looking in the Service & Maintenance Guide that for most of these items the Premium Maintenance Schedule (PMS) suggests to replace, whereas the Schedule 1 or 2 (S1/2) just says to inspect. I plan to follow S1/2.
However, I thought this would be a good forum to get feedback on these items so folks can decide whether they are worth the price, something they can DIY, etc. Here's the list and my thoughts for each item. Feel free to comment. Thanks!
*Lube, oil, and filter $34.95 - I usually do this myself but got a bunch of coupons for free oil change when I bought.
*CVT Transmission Service $199.95 - At this price I assume they would replace the fluid since that's what the PMS suggests. I intend to go with S1/2 and only ask for them to test the fluid. I read the threads here about doing it yourself, but I'm more comfortable with them doing it.
*Coolant Flush $99.95 - Again this is on the PMS. I keep an eye on all my fluid levels so I'll skip this and wait until it's required for S1/2.
*Fuel Injector Cleaning $99.95 - Kind of surprised with this since it's not on the PMS and the Owner's Manual specifically says not to use aftermarket fuel additives, including injector cleaner. I have no idea what this service involves but will likly skip it given the price (unless I hear differently from you all).
*Replace Air Filter $29.95 - Skip. I do this myself.
*Inspect Brakes & Rotate Tires $24.95 - Skip. Just got new tires in November and the guy that put them on said the brakes look fine. I can rotate the tires myself.
*Replace PCV $19.95 - Here is another one that I find no mention of in the Maintenance Guide. I assume they mean they replace the valve. I read through the shop manual and sounds like testing this part is pretty simple and replacements are cheap. I think I'll check this out myself.
*Replace Pollen/Cabin Filter $55.95 - Have one on the shelf in the garage and intend to do this myself, thanks to the awesome DIY info on this forum!
*Transfer Case Service $49.95 - I assume they mean replace the transfer case oil, which is on the PMS. S1/2 just says to inspect, so I'll either figure out how to do this myself or have them do it.
*Rear Differential Service $89.95 - Here again the PMS calls for replacing the differential oil, which would only be applicable to AWD, which is what I have. S1/2 says to inspect so I'll see if I can do it myself.
So there it is, over $700 (USD), but much of it can either be DIY or only neccessary if you want to go with their Premium Maintenance Schedule. I welcome your thoughts or tips on any of the DIY stuff. I'm planning to ask for them to explain some of these items and I'll report back here after my oil change tomorrow.
