Hopeing you have some more info to share. My 2008 RWD has 30K miles. I am not about to pay the dealer $900+ for this service! Robbery...
I have read the manual and several posts and still a little unsure about the ATF automatic transmission fluid change / differential oil change. I see you change that every 30K miles in the PREMIUM MAINTENANCE section, but never change them in SCHEDULE 1 or SCHEDULE 2 Maint.
I can do everything else on the lists and can get the ATF fluid changed for $100-$125...
Do you all change your ATF fluid (or have it changed) every 30K or ?
Differential oil change - do you have that changed also, or do most people follow Schedule 1 or 2 and not change these fluids without cause?
I Appreciate your technical experience and advice!
