30hp?
ash1y1
Car: Cars, Gadgets & Gizmos, Computers, Health, Travel
And what can you do for $300 to the ignition system to add 30hp. This doesn't seem possible, is it? Please explain.
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
You CAN"T.. the post that you got that from was a sarcastic joke. IF you read further it goes on to explain how his MSD ignition system really did NOTHING except smooth out the idle. It was sort of a waste of $300. However.. if you are running turbo with higher boost... then an after market ignition would make some improvements... but not 30hp all by itself.....EVER! Hope that cleared up the confusion.
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
It's not possible..... I think they use the same dyno as the people who sell the 'Tornado'.
The most you'd see would be like 1 or 2hp on an NA car, turbo motors would gain more, but only if your blowing the spark out (i.e. stronger ignition lets you run more boost or a wider plug gap).
The ignition will help your car to feel quicker, it helps clean up the power band a little, and generally makes it feel stronger w/ better throttle response.
I'd just go for the cheepo Crane ignition system sold in Summit for like $135 (coil and spark box). It's for a Mustang but it's all generic parts and it will work on the 240 with no problems.
hope that helps,
PaulOrlando, FL
