OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Sun Nov 28, 2010 8:32 pm
Number one..... Check engine health
Compression check
Check engine codes if any
Clean and check sensor connections
Then check your basic maintenance items and replace as needed (Plugs, Wires, clean IAC, clean throttle body, check intake manifold bolts, check and repalce vacuum lines, fuel filter, PCV valve, coolant, and oil)
Set the TPS
Check for cat cloggs
Chance and adjust timing
MAF clean only for a MAF, other stuff can leave a film behind.
