ktzed wrote:
There are coatings made for piston tops and combustion chambers so I wouldnt worry about the temp issue too much.As for the SS question, I have seen many failed attempts at making manifolds out of SS due to all the reasons listed above. 304 and 321 both can be made to work well if proper fabrication techniques are used. I know this is a 304 vs. 321 argument but all things considered, mild steel is a great material for exhaust manifolds. The fatigue strength, price, and easy of fabrication are all in its favour and if your worried about the bling factor, there are some good looking ceramic coatings that should be quite durable.Another note on bracing. Be sure that your bracing supports the weight of the turbo/exhaust system but does not restrict the thermal expansion of the (somtimes quite long) exhaust runners. I have seen some poor bracing designs that quickly cause a manifold to fail do to the TE forces ripping the manifold apart.
Thanks for the feedback. Your points are very well taken - design/execution is a very big part of reliability. As far as the coating I'm planning on using it is HiperCoat Extreme not very bling (grey) but 2000*F stable (used in Nascar/IRL/Aerospace). Not sure if it's intended to coat inside of the pipe.
Let me clarify my situation though as I don't believe it has come across very well as many responders are talking about manifold bracing for the turbos.
- My turbos will be hung in the nose of the car with turbo hangers/heim joints. - There should be no weight bearing stress on the plumbing at all from the turbos.- The manifolds will look similar to the factory ones with the exception of the addition of a flex-joint at the bottom (what one would consider the "downpipe" of the NA manifold) of each one mating to a tube that will eventually "Y" and go to the turbo flange and wastegate flange.- The return from the turbo as well as the dump from the wastegate will go into a return tube that will go from the front of the car to a flex-joint and then will couple to the triangular flange on my random technology cats.
So to sumarize the manifold will bear the manifold's weight, the tubing feeding the turbos as well as the returns from the turbos will be semi-solid mounted at the cross-member with an insulator of some sort (to allow for expansion) and the turbos themselves will be semi-solid mounted - the heims will allow for some movement that will be limited to the movement of the semi-solid mounted feed/return tubes. Torque movement from the engine will be handled by the flex joints.
I hope this clarifies my specific application - I am waiting on pricing on both thick wall (.120) 304 as well as 16 gauge 321 to see what the price difference will be. In the meantime as I don't have my stock manifolds here at the moment, can someone tell me the size of the primaries/log? I believe they're 1-5/8" with a 2" log, but I'm not 100% sure if I'm recalling these correctly.
Thanks,Nick.
