302 swap
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
bostick199
Car: 93 nissan 240sx
ok i have been looking for days on here for some information to do a 302 swap in a 92 s13. i have a full motor i have a welder and everything to do it with i just dont know what to do about the oil pan and all that ****..so if someone has a link or has done it and has some info please help iam new to this forum. and it seems to be a great one so some one please help me..
thanks marc
audtatious
Moved to the Hybrids forum where the boyz can give you a hand.
Welcome to NICO
bostick199
thanks man.. just trying to find some help lol..
audtatious
You'll get it once the boys get online tonight. Just keep checking and reading
bostick199
ok thanks man i really appreciate the help and set me in the right direction on here..greatly apreshated
WDRacing
Welcome to Hybrids and Nico Marc. If you're half decent at welding then this should be pretty straight fwd for you. As far as mounts go for the motor, the best method is to lower the motor in and either fab a adapter for the Ford mounts or fab an adapter plate for the S13 mounts. Same thing either way really. Some 1/4 plate steel will work fine for that and the transmission mount. Just make sure to soft mount the transmission or you'll have driveline issues. As far as the pan goes, there are a few options. Using the R33 Skyline crossmember free's up alot of room but still requires hacking the center section out. Or modding the stock CM by hacking the center piece out. If you look at the thread I made about the LS1 swap, you'll see I have several pics of modified crossmemembers. SO somthing similar to that will need to be done. A front sump oil pan is a must.
bostick199
can you send me the link to the page..and do they make a kit to covert it from rear to front sump pan..
WDRacing
You'll have to look around for a kit to convert to a front sump. But here's a link to all the pics I collected awhile back.
zerothread?id=218104
bostick199
those helped some i need it for a 302.. is what i need it for that helped me see that the clearance isnt goin to be that big of a deal
WDRacing
With the intake off, there is enough room to jump in with the 302 and roll around...lol.
Not to many guys have the 302 swap. I'd love to do it, but the 302 blocks are not very strong and eventually I would want more power. Anything that crack right down the middle is a bad choice for me.
WD
bostick199
lol well this is a budget build so i do what i can with what i have...
so far i have 351 heads.edlebrock rpm manifold.explore forged bottom end and forged pistons.nitros plate.holly 650 carb.f303 cam.custom headers there long tubes my buddy made them for me..so thats it so far.. i have like 400$ so far in this motor.. i dont think iam doin to bad.. i will have probably like 600$ in the end
my suspension tien springstokico struts.cusco camber plates.cusco strut bars which i can only use the rear one know..and vlsd.
Return to “Hybrids”
