302 Swap
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
240sx-T
Car: Hopefully a boosted 240
I want to know what I need to do to my car to put in a 302. I also want to know what rear end or diff will handle 500+hp and what axles to use. Feel free to add in anything that I forgot. My Car is a 91 240sx coupe.
WDRacing
The engine/transmission mounts will all be custom work. The DS will have to be fabbed as well, but you just need measurements for that. The stock R200 is plenty stout, however, you'll need a VLSD for sure. So swap in a 300ZX or J30 rear end.
WD
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
OR a Q45/300zxTT rear with custom shortened axles. The Stock rear can take power, but the stock axles are iffy. The J30 axles are better, but the Q45 or 300ZX twin turbo are the one with the most beef to them. They need to be sized however.
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
OutToWinPAHC wrote:OR a Q45/300zxTT rear with custom shortened axles. The Stock rear can take power, but the stock axles are iffy. The J30 axles are better, but the Q45 or 300ZX twin turbo are the one with the most beef to them. They need to be sized however.
The Q45 and 300ZX TT had different diffs.
The Q45 will fit as it is still an R200V with the right mix of a TT axle and Q45 axle.
The R230V in the TT Z32 will NOT work without modifying the subframe.
WDRacing
Or...just weld the diff...free + full time posi = awsome.
240sx-T
What rear end and axels should I use?
cnichols
99 Infiniti Q45
93 Ford Fastiva
Stock...until you're making enough power to break them. Concentrate on getting the car on the road and all the bugs worked out before worrying about the axles and diff. They'll hold up longer than you might think.
Ali 556
Car: '95 S14 Se....
cnichols wrote:Stock...until you're making enough power to break them. Concentrate on getting the car on the road and all the bugs worked out before worrying about the axles and diff. They'll hold up longer than you might think.
+1 it WILL hold.....SC300 on SF made 1000rwhp on his 2j/S14 on STOCK j30 VLSD....
Return to “Hybrids”
