Ok so we were going to bolt both snails up this weekend but we ran into a few problems. We only got the left side bolted up its not completely installed we still have to tighten down one nut (front right) and tighten down the other ones (I am doing it in a sequence). Also hook up the oil feed into the block.
Fitment was good except the turbo oil return pipe was too long and not at the correct angle. We ran into this problem on both sides for the left side we had to bend it up. The reason why I think the fitment was not dead on is because I have the SZ oil pan (which is a modified oem TT oilpan) and the spouts are at a different angle which is really no big deal. I just thought I would state that for people wondering in the future.
Ok onto pics:
The first couple of pics are of the turbo oil return pipe.
Notice how the rubber hose appears as if it has a kink which it does. Its a very slight bend I don't think it will hurt anything. The oil will just puddle up then go over the bump and keep on flowing. Also its not in a binde (for lack of better words its not like it is seeing any tension). Also the oil return tube is touching the compressor housing should I adjust that??
Moving on, Notice how close the hot side housing is from hitting the block.. Its very precise. (1-2 mm) I got a couple of pictures from slightly different angles.
Here is the nut that I have to finish tightening. I am worried that I won't get it all the way tight.
Now random turbo pics:
So beautiful.
Questions/comments?
