300zxtt wont stay running
squidz32tt
Car: 1990 z32 twin turbo
so i just swapped my 300zxtt and the engine only stays running if you hold the gas down but it can only rev up to 2000 rpm then it shuts off.the car has enough fuel pressure and i think that its an electrical problem. my efi harness is 20 years old and the connectors and injectors have some green oxidation on them. does anyone have an idea what my problem could be? or is anyone in the massachusetts area that can come look at it for me? that would be greatly appreciated. :gotme
PAintballa45
Car: 1991 300zx n/a (TT in progress : D) slicktop
where in mass are you? definatly clean all that green crap off everything and put dialectic grease on all the connectors. Also check your timing and make sure the tps is calibrated.
squidz32tt
im located in waltham mass do u think u could figure out the problem?? if u can, text me at 781-775-0583 the help would be greatly apprecated
