300ZXTT upgraded fuel pump
bserieshatch69
is it a good idea to upgrade to a 300ZXTT fuel pump? is there any flow advantages? will there need to be any modifications done to the harness itself? i ask this because i got quoted for both pumps and the 300ZXTT pump was 7 buck more so i figure 7 bucks and more possible flow would be a nice idea. thanks for the help.
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
Why do you need more flow? Are you turbo'd? More fuel isn't necessarily better.
PabloHoney
As repo man said, if you don't need more fuel flowing in the system, don't get it, it's just gonna use up more juice from the battery. Even with a bigger fuel pump, you won't necessarily get more fuel into your engine anyway, it just circulates more fuel to the rail, and then back to the tank...it's your injectors and FPR that regulate the amount of fuel that goes into your engine.
bserieshatch69
so do you think that a walbro 190lph unit would be sufficient for a stock boost level sr20det and up to how many pounds would it be good for?
bserieshatch69
also, what is the flow rate of the 300zxtt fuel pump?
