hurddawg wrote:He and I told you 90-96 300ZX TwinTurbo (Z32) the trannies are the same through that period.
I saw your post. You said I "believe".... so you really didn't know for sure.
I want to find someone who KNOWS this ****, not believes it or has heard it through the grapevine.
Davehoos, can you elaborate on this?
"and the main[output] shaft and shift linkages will be different"
What do you mean by "shift linkages"? Are you saying the shift forks inside the transmission? Or the shifter linkage on the outside of the box?
And you are saying the output shaft is different? Is that going to give me problems or something?
thanks
