300zxTT fuel pump?
SR20DETpwr
Car: 1992 240sx SE w/ built sr20det redtop
motor built by Stewart Engines LLC
put together and tuned by ILL Garage
.86 GT2871R @18.5psi = 393.4whp
I had a 300zx tt fuel pump in my last 240sx w/ sr20det redtop.....I always wandered why the car ran so frickin rich. The other night I read the 300zx fuel pump ran on low voltage at low rpm's in the Z; however the 240sx doesn't have this feature so the fuel pump dumps everything it can all of the time at the motor --- Is there a way to fix this so the car doesn't waste so much gas which in turn made me fill up 2-3 times a week in the old car? The reason I ask is that I can see this same problem happening again after my motor gets put into the car I have now.
cheez80
Car: percussion =D
i have the z32tt fp in my car, and i get 22mpg...
may be something else in your setup, might not be your fp.
SpeedRacer1
Car: 1990 240SX, G35
I have the Z32 fuel pump, get about 27-29mpg's. Its not your pumps, its your driving style and how well your engine is running/setup.
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
It is more likely your fuel pressure regulator rather than the fuel pump. I would just buy an adjustable one with a pressure gauge.
