A Paratroopers 300zx wrote: vulcanrush wrote:
yes, get new fuel injectors first before turbos.
No, you don't NEED them. If you plan to upgrade your turbos at anytime... then yes, you would upgrade your injectors to match. 450 is a pretty relaxed goal and not that hard to attain. Most of the common bolt ons can get you there. People have hit upwards of about 525 on stock turbos, but that's really hard to do.
and stock fuel injectors max out at about 370-380rwhp, you don't want him to run lean, do you?
for non-engineers like myself, the "cc's" (555cc's, 740cc's, etc.) are an easy way to estimate how much power the fuel injectors can support.
upgraded fuel injectors are the first thing i would get.
also, 400rwhp is the safe limit for stock turbos, imo, 450rwhp required a higher octane fuel, and 525rwhp, the turbos won't last very long if you're going to keep driving like that.
those are dyno numbers, not every-day-driving-reliability numbers.
http://specialtyz.com/blog/?p=948 447rwhp+ required
100-octane fuel, 2.5'' aspec massives ic's and ic pipings, 3'' dp's, and upgraded exhaust manifolds....that's not that easy.
