domenicostorino »
https://forums.nicoclub.com/domenicostorino-u82904.html
Fri Dec 07, 2007 8:16 pm
Hey guys I'm kinda new here... I need your help! My 300zx z32 vibrates only when I step on the gas , I can feel the vibration coming from under my seat and I know its not engine related.. so I suppose that my driveshaft needs balancing or maybe the carrier bearing is broken.
I have heard that I can get a one piece one from the z1 motorsport website and I have also heard that some people have replaced the carrier bearing (which nissan says its not replaceable) and the vibration problem was solved.
I can't spend that much money right now so I just can't buy the z1 driveshaft, I would like to go with carrier bearing replacement so the questions are:
Have you guys replaced your bearing carrier? If so, was the problem solved? where did you buy it? and the most importart one.. can any mechanic do the replacement? (are there special tools/machines needed??)
Thanks in advance!
