300zx(z32) TT clutch master cylinder work on 240 (S14)
StockSucks
Hey I was curious if anyone knew if you could use the clutch m/c from a 300zx TT on an s14 and if so are there any benifits performance wise with using that m/c. And yes I did do a search before posting and did not come up with any information..( fyi for who ever would tell me to do a search before posting!!!)
ShionS14
Car: 2003 Saab 9-3, 2005 Infiniti FX35
The only reason you would need to change to the 300zx master cylinder is if you have the 300zx brake conversion, other wise no you dont need it the stock one works fine.
StockSucks
yeah
ShionS14 wrote:The only reason you would need to change to the 300zx master cylinder is if you have the 300zx brake conversion, other wise no you dont need it the stock one works fine.
im doing the brake conversion but im askin about the clutch m/c i know nismo has a performance clutch m/c but i was curious if the clutch m/c will work and has any better perfomance than the stocker
Chezedik
Car: 1991 Nissan 240sx
If it has a smaller bore then there will be no benefit, if you use a larger bore in the slave it will require less pedal travel to create necessary volume, since pressure is only possible when there is resistance to flow, flowing more with the same slave will create more pressure. That is why Nismo makes the special slave cyl.
ShionS14
sorry my eyes just glazed over when i saw 300zx and conversion, i automatically assumed brakes.
s14junky
Car: 95 240sx
If you need a Z32 master cyl i have one. $40 shipped
[email protected]
