Ev_eezy wrote:Thread created to make this topic easily searchable.
I'm getting a bit of the run around on this topic and want to have the real answer posted in this thread.
So far I've confirmed the following
-Z32 Eibach (pro-kit) springs will not fit directly onto a Q without slight modifications.
-Modifications will include cutting down the spring cushion from the Q to fit the Z32 spring. The Q's cushion is too big, that is why it needs to be cut.
-The number for the front springs in the Eibach Pro-Kit is the sequence of numbers which ends in 001
-The number for the rear springs in the Eibach Pro-Kit is the sequence of numbers which ends in 002
MY QUESTIONS
1. I've heard z32 struts/shocks will fit onto a Q as long as you use the Q's strut mount. Is this correct? Can someone confirm this?
2. Given the weight of a 300zx vs. that of a Q45, should I be concerned about using KYB AGX (adjustables) struts/shocks from a Z on a Q? Would they be any less reliable because they're not for a Q45?
3. Going back to using z32 springs; Does anybody know if its possible to use a Z's spring cushion on a Q45 strut to fit Z Eibachs?
All input from those who have done this, and those who know something about this is much appreciated. I'll post my results WITH GOOD PICS to confirm everything and have the truth on this once and for all...
OK here are my thoughts.....
If you must use the Q45 top hats with the z32 struts then you still have to modify the rubber bushings on the top hats.
I would guess that the z32 struts have more dampening or are stiffer then the Tokico's we normally use. I don't think they will wear out too much faster because the weights are similar. Heavy cars automatically wear shocks/struts out faster then light cars.
As for the tophat rubber peices-see my first thought. I don't see how they would be any better then a modified q45 part.
And lastly, would I do it again?
The car drives great if you are looking to make a 4500 pound car into a "race" car. That wasn't my goal. I already have a highly tuned 240sx and WRX that ride like sh*t. I wanted sporty, not floaty or bouncy.
I am thinking I might try the stock z32 suspension. The stock springs should be a bit shorter then the q45's and the struts a bit stiffer. All I need to do is modify or make new tophats and I am in. I am going to do a post in the z32 forum and see if anybody would like to make a donation to our cause. If so, I may have a brand new suspension set for sale. I am into it $500.00. Anyway, we will see.
