evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Nov 01, 2004 8:31 pm
as long as your running moderate boost and invest in a good A/F gauge you should be ok, 5-6 psi the stockers should keep up with a good FPR I recomend the aeromotove, I had a bosch on my car but it was a bit moody, as for the FMU I'd recomend a full stand alone, for the little extra money you get the abulity to program everything such as boost retard! it just depend on if you want a little improvement or a lot ! you can go low boost and pick up 50-60hp? or go balls out and double to tripple what the engine originally made! rome wsn't built in a day and you don't have to do all your mods at once, but be sure to run a good A/F gauge and stay conservitive with the boost, it's easy to get greedy and pop a motor, Ishould know I got greedy with Nitrous....ONCE ! so I try stay within proven limits when it comes to boost, but I'm sure you could pick up a set of Z31T injectors at a Junkyard for very little cash and give yourself a little extra room for error
