NolimitZ32 wrote:WOW!, dare I ask if it starts by crossing wires have you checked if it closes the circuit when turning the key? could be as simple as a worn contact in the IGN cylinder.
new cylinder!!
now when i jump it out ---per fsm ---ground brown/wht wire --this bypasses alarm system----it will start with key........BUT>>>>>>.............will only run for at the most 10 seconds----will start and run everytime with no prob ---but wont run long---fuel pressure is fine
i cant even rev it up!!
come on...someone got help out here.....im about burned out
i was thinking it might be the ECM---but i have no codes but 55
i could take a ecm out of my other cars and try----is a manual trans ecm different than a AUTO??????
