Ace2cool wrote:No, an N/A ecu is an N/A ECU. Easiest way to check spark is to pull a plug, ground the threads of the plug out on the plenum, and have someone crank the engine. If there's spark, you're looking at another problem.
Do you hear the fuel pump prime when you turn the key to the "ON" position?
i checked last night and i have spark but no fuel to injectors???I unpluged the coils and turned the cas by hand to see which ones were getting fuel..i pulled the spark plugs and only cylinder number six was getting fuel???
Things i have checked:
turned cas by hand fuel pump primes,i checked fuses next to battery there all good,checked fuses under steering wheel all good,i also checked the egi and the ign coil green cube fuses they seem to be fine ,injectors read 12.9 ohm all of them,i have the older style ptu but it is working i have spark
What might be causing the problem?thanks
