evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Jul 18, 2007 6:24 pm
why won't it run? lack of spark? or lack of fuel? easy way to find out, pull the injector plugs, and give ti a shot of starting fluid (it's best to spray this in the intake past the mas), if it fires right up you knwo your problem was fuel, if not then you have a spark problem or both, could also be the ECU, or the CAS which is in the distributor, or maybe the ignotor, please tell us more, what has changed other than the listed parts since it last ran? and we'll assume the timing belt hasn't snapped?
