evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Oct 15, 2007 7:56 am
ti already has an r200, they've been in every z cr from 81 till 90 then n/a z32's and all z33's they also came in some 77-80 models
anyhow, kinda a vague discriptions, I'd start by just giving everything a visual checkup, look for signs of play at the wheel bearings and at the pinion bearing, make sure everything is tight and clean, check the trans and diff fluid, not a bad idea to go ahead anc change them if you don't know when they were last done
