SmithSR wrote:Can you link all the threads you read?
here is onehttp://forums.nicoclub.com/zerothread?id=180084
in that one you said that the 7.5 inch wide wheels with 205/45s would just barely fit
zerothread?id=110366that one is titled for s14 se wheels, but you talk about the same fitment (205s) on the z32 rims being the only size tire that will clear the spring perch.
these threads dont have replys from you, but they do contain some of the information I have been readinghttp://forums.nicoclub.com/zerothread?id=126084http://forums.nicoclub.com/zerothread?id=95557
Right now I have my old s14 se sitting on the front (205/45) and the 300zx N/A wheels sitting on the back (245/45). the s14 wheels clear the KYB AGX shocks I have (slightly tapered spring perch). I have megan coilovers in the mail right now. The problem with those, I think, is that the shock mount below the spring perch takes up more space, and so you actually need a spacer to get the wheel all the way on the hub, let alone having the tire clear the spring perch.
I think I am going to wait until a set of TT wheels go on sale, put them on the back, put the N/A wheels on front with like a 10mm spacer, and still maintain a flush look with no spacers in the rear (8.5 inch wide tt w
