300zx wheel spacers size front?
sdkid123
Car: 1990 Nissan 300zx NA
Front rims barely fit and I know I need spacers
Should I get 5mm spacers or 10?Rims still turn I can probably sand down the nissan logo a bit and won't have any touching,what do you guys reccomend?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Well the RIMS don't seem to be the problem, but rather the WHEELS. Throw a 5mm hubcentric on there and call it a day. I don't like using spacers, but since you already have the wheels, make due with what you have.
TTkickedin
Car: 1991 Nissan 300zx TT 5 speed, t-tops, < currently in intensive care unit!
2011 MBTA BUS
It depends on the offset. Do as little as a spacer as you can. i have a +45 offset wheel all around, and I use 5/14th spacers, which was more than I needed by a few mm... I didn't want the fronts sitting out more than the rear, so I added spacers all around.
I also dislike using spacers, but they do get the job done when offset is the suck.
