300zx wheel clearance issue
zenkii
Car: 95 240sx
Alright, i have a s14 w/ coilovers and z32 brakes. So i bought some 300zx wheels w/ tires today and found out that they are rubbing against the front coilovers. The tires are 225/50-16. This is pretty ackward because my stock se wheels fit with no issue and not these 300zx wheels...help please? i was thinking to fix this problem i would need spacers and extended studs, which i don't want to do...so do i resell them
Rex
Car: None
What size offset Z wheels are these?
I'm thinking they're NA's, not TT's.
zenkii
Car: 95 240sx
Rex wrote:What size offset Z wheels are these?
yes i believe they are NA too, somehow they are chrome....anyhow is the only way to make it fit is through a 5mm spacer?
Rex
Car: None
If they're 16x7.5 +45's, they're NA and you're gonna need something to "un-sink that battleship" .
zenkii
Car: 95 240sx
Rex wrote:If they're 16x7.5 +45's, they're NA and you're gonna need something to "un-sink that battleship" .
Dang, i'll just purchase back some SE wheels to save all the headaches
Rex
Car: None
zenkii wrote:Dang, i'll just purchase back some SE wheels to save all the headaches
That's the best idea.
Of course 4 Z32 TT rear wheels are a great option, if you can find them ... but they're almost certain to be more $$$.
zenkii
Car: 95 240sx
sad to see that i just bought it and few hours later gotta sell them back out...
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
i have the same size tire/wheel combo on the front of my s14 i just ran a wheel spacer on the front i believe it was 3mm and the tire now clears my stock struts.
zenkii
Car: 95 240sx
HxC_Nismo wrote:i have the same size tire/wheel combo on the front of my s14 i just ran a wheel spacer on the front i believe it was 3mm and the tire now clears my stock struts.
Thanks for the info, but i've already sold the wheels the following week. The clearance just gave me a super headache so i didn't want to deal with it. But after i go ka-t, i'll probably look into a set of z32 TT wheels instead
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
yea the Front TT wheels or the n/a wheels (same wheel) 16/7.5 WILL NOT clear coilovers with out a pretty big spacer altho will clear a spring shock/strut setup with 4MM spacer but i'd get the 1/4 inch Cuz thats what i use to run on my car and it was still really close
Grab up some 350z wheels FTW!!!!
first time s14 owner
Car: 1997 Pathfinder SE 4x4
so, I just bought some 300ZX NA wheels and mounted 205/55 and 245/45s on them. Am I going to have issues mounting them on my stock S14?
zenkii
Car: 95 240sx
first time s14 owner wrote:so, I just bought some 300ZX NA wheels and mounted 205/55 and 245/45s on them. Am I going to have issues mounting them on my stock S14?
I'm not sure because you got different tire sizes, which i got factory spec tires. I guess you would have to wait for the experts on tires to reply....but for sure stock all around required spacers (if you got coilovers)
I found some 5mm spacers, I think I'll pick up a pair for the front, I'm pretty sure the rears should clear no problems.supsension is as it came from the factorydid just your tires rub, or were the rims an issue also? I'm also using Q45 calipers, so those shouldn't be a problem.THANKS AGAIN!
zenkii
Car: 95 240sx
I had z32 brakes and only rubbed tires against the coilovers
hopefully I shouldn't have any issues then with 205/55sAnyone else care to comment?
