300zx turn signal problems
joshmaier
Car: 1990 240sx silvia/1990 300zx
i have a 1990 300zx and for some reason the turn signals dont work and the ac doesn't work either.the hazzard lights work fine and all the other lights too. Is there a relation between the turn signal and ac?both used to work and quit for some reason. Could it be the turn signal relay, but i dont know where that is located. can anyone help??
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the are not connected in any way I'm aware of, I assume you've checked fuses and fusible links already?
joshmaier
yeah everything checks out ok, thats the weird part, im clean out of ideas on this one.
Nonsense
Car: s14 zenki
I also have this problem my Left Front blinker doesnt work,and The Ac isnt blowing Cold.I put the Bulbs from the Right Blinker to the Left and it didnt work.Maybe i need new fuses? not sure which ones to replace though
cjparker1
Car: 90 300zx, Turbo lancer oz, Turbo 96 maxima
My bulbs didn't work on one side of the blinkers either....I wiggled it around a bit and found out it was the terminal, so at first I put some tinfoil around the outside to get a good connection then I eventually just cut the bulb holder out from a junkyard and rewired it into mine....If it's not the fuses I'd get a meter and check to see if those terminals are even getting a power and grounding....and my ac also didn't blow cold....are you sure it's holding enough freon? Is the compressor kicking on....but not blowing cold? From what it sounds like you're not sure if your compressor is kicking on.... Are you just talking about the led on the ac switch being out? lol... I wouldn't run the compressor anymore until you get it topped up....it takes r12 if it's before a 94....and that stuff is like 8times the price of r134 lol...I know it sucks...so I'd take it to a shop to have it done right. R134 isn't compatible with your drier in the system and valves and also lubricant....so you need r12 which you can order offline but you need the valve and gauges too....and u need your system to be vacuumed out anyways to be at 0 or negative vacuum to have no air in it....so I suggest letting a shop do it and they will find leaks too...
joshmaier
i think my problem is more complicated then that, like the ac, nothing works the ans don come on, compressor doesnt, its like the whole system is dead.
Garry_Knight
Car: 1990 300ZX Twin Turbo
@Joshmaier, I know I'm bringing back the dead here.. Did you ever actually figure out what was causing this issue? I'm having the exact same issue. Except I can't get any power out of my AC functions. Please let me know. Scratching my head on this one.
G300zx
Car: Nissan 300zx N/A
I have a 93 300zx N/A and my blinkers are not working but when I put the hazards they work. I checked the fuse and the relay and everything is ok. Idk what it is.
