300zx turbo...transmission
BlackQ45
Car: Infiniti Q45 1991
I want to fit a 300zx turbo on my 91 Q45 but i got some fear about my transmission...is this a good idea?? cause i live in Quebec and Q45 part are praticaly unfindable and really expansive...i dont want to break my only transmission!!
And by the way...someone have an passenger headlight and corner light for sell??
EQwhipD
Car: 1994 Q45 (Totalled)/ 1994 Q45a (SOLD) / 1990 Z32TT
Someone correct me if I am wrong, but the 300ZX (Z32) Twin Turbo auto transmission is identical to the Q45 transmission. The regular (NA) Z32 comes with an auto transmission identical to the J30 (much weaker before 1993). Hope that this helps!-Evan
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Yeah theyre the same-ish, youd have to swap bellhousings. Its never been done so no guarntees it will work without a hitch.
Hodo
Car: 1995 300ZX
Do you mean swap bellhouseings between the NA 300ZX transmission and the TT AT?
Cause the TT AT bellhouseing is identical to the Q45 Transmission. Even down to gear ratios. Later model Q45s got different gearing in them but I also think the twin turbo Z did too. Its the same RE trans.
elwesso
2007 BMW M Coupe
The bolt pattersn on the VG vs VH are different, therefore you switch the bellhousings.
