300zx turbo on ka-t
coolcloo1019
Car: street racing
Now as far as I know..the stock t-25 from a 90 300zx will work right...my friend has an extra thats why i am asking. what DP would I use? Would the DP for the SR work? Im new to the Ka-T but thats what i want now. Thanks.
Modified by coolcloo1019 at 5:10 AM 11/11/2004
GEO
Car: 95 240sx KA-T
Just get a custom DP made..
hannibal
Car: Red Line to Glenmont
I think Ive heard of a T25/manifold combo that uses the stock SR downpipe. Dont remember who made it, but assuming the VG T25 and SR T25 are the same, it should work for you
coolcloo1019
Car: street racing
Alright cool, thats what I thought but I just wanted to run it by some other people first. Thanks.
SeVa-S13
Car: '05 GTO 6spd
I'd be wary, will it may have the same flange, the turbo is designed to have quick spool on effectively a 1.5 liter engine. If you're really set on a T25, maybe look at the SR one?
WDRacing
The T3 from an older Z is the turbo you should use, the newer twin turbo Z's are much to small for a 2.4 liter motor.
andrave
Car: 1989 Nissan 240SX Coupe
z32 is way too small, its actually a T22 (which technically is just a variant of a T25).The downpipes are different also, some of the Z32 turbos use a different flange...in general its just not the best idea.
coolcloo1019
Car: street racing
Alright, so I guess the T-25 isn't a good idea from the z32. I don't want to go with a big turbo, just looking to get a little "pep in the step" so thats why I was looking at the T25. Are you saying its too small all together or just that the T25 from the z32 isn't going to be good. Should I look into a T25 or T28 from an SR? Sorry for all the questions...nooB :/
SeVa-S13
Car: '05 GTO 6spd
T3 from a pre 88 Z31 like WD said will give you pep while not killing your top end and can be had very cheaply.
hannibal
Ive heard of people running SR T25/T28, but I personally wouldnt try anything smaller than the T3 from a Z31 (84-88?). The earlier ones were watercooled.
masamunex03
Car: nor is this
Z31 t3=84-87Z31 t25=88-8984=oil/air cooled85-89=oil/water cooled
