Z32TT »
https://forums.nicoclub.com/z32tt-u119434.html
Thu Jul 02, 2009 7:05 am
alright with hondas all you pretty much have to do is switch to an intake manifold with an evap purge and usdm ecu with cat hooked up of course to get through BAR N REF except JDM type r you will fail regardless bc compression to high..anyways on to your answer
if its an NA with a TT swap and someone knowledgable is testing it then you wont pass bc visual if you go to JOE Shmoe then he prob will just run emissions as long as your cats are hooked up you should pass, if you have a JDM swap and want to BAR n REF then all vaccum lines must be hooked up and emissions with an USDM ECU for a TT and all lines should be black they usaully fail you if they see EX. red vaccum line considered performance part they are super strict, the only differnce between JDM engine and USDM mainly is the downpipes USDM has pre cats but from what i know as long as your main cats are hooked up you should pass
BTW last i heard they stopped doing visual at BAR and were just doing the emissions but i cant confirm that its what i heard and if this is true that makes it alot easier for people to pass since most fail visual
