300zx tt smoke
Azazel703
Car: 300zx z32
I have a 300zx tt that im haveing problem with it smoking. It doesnt realy smoke at idle more so after you rev it and comes to a stop for a few sec then seems to go away also it doesnt seem to get worse in boost just after i stop i can see smoke. The smoke looks kind of white but hard to tell
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Smoking out the exhaust? If so probably leaking oil seal into the exhaust turbine wheel.
Had the same issue with my last turbos. Drove fine, boosted fine but once I come to a stop at a light white smoke would come out the exhaust. Oil was leaking out the turbine wheel onto the hot down pipes.
