300zx TT oil leaking from passenger turbo into exh. and inta
kaedachef
Car: 1990 Nissan 300ZX N/A
I am in the process of removing my passenger side turbo, found a lot of oil in my intake and intercooler piping on the passenger side. it stopped about 2 inches from the filter. Also there was a sh*tload of oil coming from the passenger side exhaust. Im 99% sure its the turbo, but ill find out once i get it off and check inside the exhaust manifold ports. ALso I am removing the turbos with motor in the car. Impossible is an understatement but it has been done and I do not have the money for a engine hoist to lift the engine. To make a long story longer I am stuck at the 2 exhaust manifold nuts behind the turbo. anyone have any experience getting these off. Also when i was contemplating on blowing the car up i accidentally cut the clutch line to the passenger side bleeder. Do i need this line or can i just delete it. any help guys would be much appreciated. thanks
kaedachef
bump
Chase300
Car: 1990 300zx TT
your best bet is to undo the downpipe bolt up to your test pipes, and then removed your head bolts and take the whole thing off with the turbo and exhaust manifolds still attached. Thats how ive done it. Youll also have to unbolt your oil line to the turbo.
kaedachef
I'm trying to do it without removing the head. i know it has been done. i just gotta keep at it. but anyone have any input on that hardline for the clutch by the fender.
NolimitZ32
remove PS pump, alternator, get all wiring out of the way, remove exhaust and PS downpipe. From there you will either have to buy some crows foot wrenches and flex joint or fab your own tools to get to the turbos because the FSM actually says that you have to remove the head to change the turbo so this is a "auto-enthusiasts do it better" procedure.
kaedachef
the thing is i dont have to take those out. There are not in my way. It is just those 2 nuts behind the turbo.
NolimitZ32
More space = easier access.
like I said you gotta fab you a wrench that will reach them, or if you are desperate cut a slit in the nut (be careful not to damage the threads on the stud) and chisel it off.
kaedachef
Hey guys well the nightmare is over. Got those 2 bolts off with a 1/4 drive universal and a short 14 mm in 10 min. I had a feeling that the 3/8 was not getting the clearance,so i bought the 1/4 drive uni and bang. Now to pull the manifold/turbo out and change em up.
kaedachef
anyone know how i can check to see if my seals inside my turbo are good before i put it in. do not want to have to do this again.
NolimitZ32
Do you have oil in the turbine housing? if so and depending on the amount they are either bad or on their way out, also hows the shaft play?
kaedachef
Theres no oil in it. And has barely any shaft play
NolimitZ32
So where is the oil coming from than?
kaedachef
Im taljing about the new turbo not the one that was in there. The on ethat was in there is leaking alot of oil.
kaedachef
The new turbo is used with very little shaft play. Im just curious if i should run oil through the line and spin the turbo and see if fluid comes out. Not sure if that is how i test it
kaedachef
finally got the turbo and manifold out. not cant get tje nuts off for the turbo to manifold. i bent bacxk the braket thing but they wont come off. I am soaking them in pb blaster hopefullly that does the trick. Anyone got any info on this of tips. It would be much appreciated.
NolimitZ32
problem is you wont be able to get the turbo to the heat and rpm without and extensive test setup so no there isnt really a way to test it in your garage, yes you can pour some oil in there, if it comes out the seals are completely f*** but they may be in ok (but sorta letting go condition and wouldnt show leaks till its on the car and running for a few days.
