amaderojr »
https://forums.nicoclub.com/amaderojr-u219525.html
Thu May 02, 2013 10:51 am
OK I've spent hours doing research and am not being able to figure this one out. I just bought this 90 300zx TT, supposedly rebuilt with like 500miles on rebuild. ( just some background info). So I put a boost gauge because it just didn't seem as fast as it should, (I also own a Galant vr4 awd turbo, and that seemed to pull harder) and it is only boosting 4lbs. So I went through everything and noticed that it was put back together without a destination sensor, so I bypassed it until I can get a relocation kit. So now I have a code 55 but still only boosting 4lbs, so I disconnect the safe boost solenoid on the wastegate and still only 4lbs. So I try unplugging and blocking off the waste gate vacuum lines ( and I know this is very dangers so I ran 100octane to lower possibility of detonation) and what do you know its pushing 15psi. (Only ran it the once). So I want to know if anyone knows why its only pushing 4psi with the wastegate vacuum connected?
