BrianZ32 wrote: ↑Tue Oct 17, 2017 2:54 am
To answwr you guys, he had bought a Z that came with the parts, i guess he was supposed to put it all together but either lost interest or just decided not to. He contacted me and seems to be in need of some cash which is why im assuming the low price. But im always very skeptical with parts such as this. Keep in mind i would not be doing the work myself, as much as i'd love to, i have no idea how. Rookie. There's a specialty Z shop local and i always go to them for advice. What do yall think? I have no idea what im looking at as far as labor costs if i were to even consider purchasing this guy's motor and such.
This being the case I would say at minimum:
1. Trun the engine over by hand with a breaker bar, it should turn over smooth with a bit of resistance at each stroke's TDC with the plugs in, and very very easy with the plugs out, if this doesn't turn at all it may still be a usable but most likely its seized.
2. Pull the plugs (if you hadn't for the previous step) and check to see if there is any ATF in the cylinders, this is a common way to try to un-sieze an engine, if this was done to the engine that means it sat somewhere for a long time allowing moisture to seep in and oxidize the cylinder walls at the rings. Again, not catastrophic but certainly not a positive.
3. Do a leakdown test on the engine (you-tube and google are your friend), you'll likely have to buy the setup or borrow it from a shop if you have that sort of relationship with one, you don't need anything fancy (harbor freight will do), you will need an air compressor as well. This will tell you the general health of the seals, gaskets, and sealing surfaces, this will also let you know if there are any bent valves.
4. If the guy will let you and you aren't too apprehensive, pull the oil pan and valve covers and have a look at the general state of things, since you wont really know what you're looking for I would suggest finding someone who knows to help you out or paying your Z guy for a couple hours of his time, pull everything first, then invite him over, he'll appreciate your appreciation for his time. Also if your Z guy is the one that will be doing the install you may be able to strike a deal with him on a discount or even looking at the engine for free.
Unglued13 wrote: ↑Mon Oct 16, 2017 8:51 am
I'm not the OP but also deciding on doing a TT swap or buying a TT. The idea of buying an engine off Ebay has put me off the swap. How would you go about looking for a motor if you were doing this today? You mention calling importers.. Is this as simple as google in auto importers? Also mention contacting insurance companies... Is this common? I was pretty sure insurance companies sell the salvage cars at auction or to salvagers and don't deal with the public directly. I'm actively trying to source a motor as it's the deciding factor on if I'll do a swap or not (I actually want to rebuild the motor while shopping for the right body/chassis for it).
Thanks,
Your answer is simpler. If you have a NA and it runs well and is in good shape and you don't have a particular special connection to it the best route is to sell it and buy a TT, less hassle, less pain, and believe it or not MUCH less money spent in the end. If you must swap then Dcaff covered it.
