My 300zx TT have a problem
I was driving highway, i shift down to 3 gear and drive high RPM over 7000RPM
And shift to 4th gear and i saw back mirror and see huge smoke looks white??
Whats going on? My motor get bad now??
Help me out please
If you sure it's white then you might be having some HG issues. I'd check/watch your coolant level and consistency of your oil. You can also run a lab check on your oil, this will tell you if you have anything unusual inside your oil. Like.. coolant in oil.. or excessive metal...it's kinda like a engine health check. Black Stone Labs is an example of a place that does a test.Rule of thumb is that: white smoke is usually caused by coolant water (or antifreeze) entering the combustion chamber; blue smoke is essentially due to oil (lubricants) getting in to the cylinder; and black smoke is generally because there is too much fuel (Diesel / Petrol) being inducted / injected in to the engine. And grey smoke would be due to a mixture of water and (excess) fuel entering in to the combustion chamber
