Yep.300zxtwinz wrote: Okay I know tht most people absolutely disagree with the fmic on a 300z
I think it looks like a FMIC a copy at that. It will not out perform a pair of quality sidemounts. The only FMIC worth a damn would be the TDM, (I have also heard good things about the real HKS) but since you have to delete AC for the big core TDM it's basically track unless you don't care about AC.300zxtwinz wrote: Let me know what you think about it
Oops. You can't get mad at people for bashing at the idea of a FMIC on a z32 especially when you know people will. It is like going to a h0m0 convention wearing gay looking clothes and then getting mad because a bunch of gays hit on you.300zxtwinz wrote:and please don't bash on me because its a FMIC.
Lol, you been drinkin buddy? hahahaha300ZXttZMAN wrote:It is like going to a h0m0 convention wearing gay looking clothes and then getting mad because a bunch of gays hit on you.
Hehe, nope I wasn't. Just wanted to have a "fun" post.NolimitZ32 wrote:Lol, you been drinkin buddy? hahahaha300ZXttZMAN wrote:It is like going to a h0m0 convention wearing gay looking clothes and then getting mad because a bunch of gays hit on you.
Not necessarily. Radiators are air-to-water cooled. If you put a huge wind-blocker in front of it restricting flow to the radiator cooling fins, then upgrading radiators is not going to resolve that issue - the obstruction still exists. There are already enough things blocking the radiator's airflow: intake, a/c condenser, and oil cooler. The last thing it needs is another large dense object placed right in front, obstructing more flow. Our rad fans are belt-driven, so if you sit at idle or cruise low speeds in the heat, your engine will likely run hot.300zxtwinz wrote:Also if you upgrade the radiator you wouldn't have to worry about the engine cooling so much.
Just search, man. Just go to a vendor's website and look up their prices.300zxtwinz wrote:What are the costs of good smic set can I get a new set for under 400?
Nismo 740's are the only ones you should consider if your looking for something in that flow range. Stay away from the jec's, deatchworks etc.300zxtwinz wrote:That's pretty good for some pieces of aluminum hahah
How do you trust like regular JECS 740cc injectors?
300zxtwinz wrote:Cool I will do some searching on a set of good smics. How much hp would upgraded smics add by them selfs? Do they add anything?
300zxtwinz wrote:So wait do you recommend using a front mount? Like the kit I posted what do you think about that, seeing as you are running a FMIC @EM.TT
The Z is not a car to try and go cheap on unless you like buying parts twice, that or your going to get frustrated and sell it after your crap parts ruin the car passing your failed project on to someone else. Not trying to be mean but you seem to be looking for any excuse to justify what sounds like you have already made up in your mind of running a cheap fmic. As has already been said if your set on a fmic there are a couple that do work TDM or hks (though i would stick to the TDM only) both of which are not cheap.EM.TT wrote:
I agree with everyone about smic's being better in most (probably all?) cases, BUT:
Noticed a big bump in how well it resisted heat soak even on hot days, but gained spool time and a bit of power over stock smic's with the provided piping from that kit.
