Chase300 »
https://forums.nicoclub.com/chase300-u144215.html
Mon Aug 09, 2010 9:59 pm
woa steering knuckle whaaat.. no non o... pull your plenum pull all the wiring harness off drop your a/c alternator and p/s pump drop exhaust driveshaft starter then transmission (top bolts youll need extensions and swivel to ease this process)
downpipes stay on the turbos un bolt cats. make sure radiator is out and 4 airway pipes off (2 to plenum 2 to turbos). Pull motor. Dont touch steering or rack. if you do then you might as well leave transmission attaached to motor and jack the car up over the motor instead of pulling the motor out. you will need an alignment after if you do it that way.
