s14=pimpin' »
https://forums.nicoclub.com/s14-pimpin-u202.html
Sun Aug 25, 2002 8:14 am
[quote=" Daunttless
its just as easy to put the CA18 and S13 SR into the S14, the wiring is just a bit more complex. Its still the same mounting locations for everything. [/quote]
hey Dauntt,
its not the first time I've heard the red top SR is an easy drop into the S14. How much harder is it to install an S14 black top into a N. American S14, and what the heck was Nissan thinking? Wouldn't the mounting points be the same, since its the same car with a different motor?
Also, didn't you mention in another post that the CA motor is a good buy if you want over 500HP? So is there really a need to get the inline 6 of a Skyline if all you are looking to do is get 5-600 HP outta your ride? The CA would be a more cost effective solution for 600HP, not to mention probably lighter, so the balance of the 240 can somewhat be maintained, in order to do well on a autocross course, right? Well, on second thought, you also said the RB motor can handle 600HP stock, with some upgrades obviously, and I'm sure the CA will have to built all over. Well, my question to you is what would be the most cost effective way to obtain 500HP without harming the balance of the S14, in order to make it a good autocross vehicle? Also reliability, I know they are all Nissan motors, but in your opinion, would one be better than the other?
just asking
