DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Thu Feb 26, 2015 11:51 pm
I agree with Ace on the front side of this issue, hopefully that is the case. Check your idle air control valve and all of those larger hoses which also connect to the PCV's, and also check the nozzles coming out of the valve covers as they come loose and may also produce a vacuum/boost leak. BTW, a vacuum leak becomes a boost leak under boost so keep that in mind.
As for further advice if you find nothing wrong in those areas as I did not during my own issues, it was determined later by my Z mechanic that ALL of my various seals were leaking enough, along with some timing issues related to an improper tb install and further "mods", that combined would not produce boost past 1-2 psi which mimicked turbo failure and IACV issues which actually never was the case.
Hope this helps...
